Have fuel and spark but will not start?
Old May 27, 2012 | 08:55 PM
Deadlymopar408's Avatar
Deadlymopar408
Default Have fuel and spark but will not start?
94 Dodge Ram 1500 w/ 360. I just recently found out that the oil pump driveshaft had a certain line up to it so I readjusted it and now the truck will not start. The reason I had to readjust it was b/c I blew a head gasket due to preingition denation. So any idea wtf is wrong.
Old May 27, 2012 | 10:26 PM
dhvaughan's Avatar
dhvaughan
did you remove the distributor?
did you mark it and put it back in the exact same place?
if not, you need to set the fuel sync, aka when the injectors fire.
Old May 27, 2012 | 10:53 PM
gdstock's Avatar
gdstock
Something else is missing here. "found out that the oil pump driveshaft had a certain line up..." How does this get "misaligned" when changing head gaskets?
If we know everything that was done it would be easier to figure out.
And + 1 on fuel sync as dhvaughn mentioned.
Old May 28, 2012 | 06:58 PM
Deadlymopar408
when i was rebuilding it I had no information on that drive piece so when we got it all together it ran like ****. So when I torn it apart again for the 4 time, I decided to do some invesgation on it. So I contacted Bg Performance and the gentle men their had informed me to go to a dealership and ask for the alginment. They printed it off alldata and I made the adjustment and now the truck doesnt want to run. But before the truck start and moved but ran like ****.
Old May 28, 2012 | 07:12 PM
Ramzy's Avatar
Ramzy
Really sounds like a fuel sync issue to me. Can only be set if you have a scanner that can read the data or the dealership can do it. I can't think of anything else that would cause this issue. Especially since the distributor was removed. Why did you have to remove the distributor to replace a head gasket?
Old May 28, 2012 | 08:59 PM
Deadlymopar408
I removed the distruber due to the fact the DRIVESHAFT for the oil pump had to be put in a certain way. At the time of assembly I had no information on that part. So after blowing 3 sets of head gasket I did more investigating and found that I need to be put in a certain way. so while i had the intake off I set it to its correct position.
Old May 29, 2012 | 01:07 PM
Ramzy's Avatar
Ramzy
Ok, re-read first post. Adjusted due to preignition detonation, ie. pinging. I think your fuel sync is off and that will give you a no start condition. Adjusting the distributor does not affect the timing at all and more than likely won't cure the ping. The most common cause of spark knock on our trucks is a blown plenum gasket and incorrectly routed spark plug wires. Is this the 408 you posted about a few months ago. If so, did you ever get the PCM issue resolved? If not this may be part of the problem as well. Just realized you have multiple threads about similar issues.
https://dodgeforum.com/forum/2nd-gen...eration-2.html
https://dodgeforum.com/forum/2nd-gen...-overflow.html
If you didn't correct this and haven't had the fuel sync reset that is your problem. This must be done or it will never run right if it will even run at all.
Old May 29, 2012 | 04:32 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Sounds to me like it's 180 out. Dizzy or timing chain. But maybe this will help.
http://www.bionicdodge.com/Download/...uel%20Sync.pdf
Old May 29, 2012 | 05:06 PM
Deadlymopar408
Yes this is the same 408 I have been having issues with. B&G Performance had told me that the pcm was programed to my specs and if needed how to adjust for retarding the system. I had asked about the oil pump driveshaft and if it needed to be aglin in a certain why, yes and thats why I had the preigintion dentation deal/ pinging problem while acceralting. (pardon spelling)
Old May 29, 2012 | 05:08 PM
Deadlymopar408
That last bit of info was alot of help b/c that is excatly what i'm dealing with far as the scan tool goes this truck is OBD1 so can't really do anything. But the CPU was programmed ahead of time.
